Home Edge & Detail Trimming
Trimmer
Shop All Trimming Products
Achieve clean edges and precise trimming with a robotic solution designed to reach where mowers can't. Automated lawn trimmer for borders and hard-to-reach areas. No missed spots. No manual trimming. Just a flawless finish.
Fast Delivery
30 Days Free Returns
11 Item(s) Found
HOW YARBO WORKS
Set Up Once. Trim All Season.
  1. Install the RTK Antenna
    Mount the RTK base station in your yard. It communicates with your Yarbo Core to deliver centimeter-level GPS positioning — the foundation of wire-free navigation for the Trimmer module and any other module you run.
  2. Map Your Zones in the App
    Open the Yarbo app and draw your fence lines, garden borders, and driveway edges directly on a satellite map. Adjust trimming zones anytime as your yard layout changes.
  3. Yarbo Gets to Work
    The Trimmer module pairs with your Lawn Mower, Snow Blower, or Blower module on the same Core — swap based on the season, no extra equipment to store or buy.
WHICH TRIMMER PACKAGE IS RIGHT FOR YOU?
All Trimmer Packages are currently out of stock. Use the guide below to find the right combination for your yard — then join the waitlist to get notified when it's back.
if you want autonomous debris clearing paired with precision edge finishing.
Need more than one?
The Trimmer module can be paired with any combination of the Lawn Mower, Snow Blower, and Blower modules — see available bundles to build a system that covers your whole yard, all year.
ROBOT TRIMMER vs. TRADITIONAL METHODS
Is Yarbo Trimmer the right fit? Here's how autonomous trimming compares to the alternatives.
Feature Yarbo Handheld Trimmer Trimming Service
Time added per mow None30–60 minutesNone
Recurring cost One-time investmentFuel/battery costsPer-visit or seasonal fees
Scheduling App-controlledManual, whenever you get to itSet by provider, not always immediate
Year-round use Yes (modular)Trimming season onlyVaries by service contract
Skipping edge trimming is easy when time is short, but the borders show it first. See how the Yarbo Trimmer module compares to doing it yourself or paying someone else to.
Beyond Edge Trimming: Year-Round Yard Care
Yarbo isn't just a trimmer — it's a modular platform for complete yard care automation. The Yarbo Core is designed to work with multiple modules:
  • Trimmer Module - Precise borders, fence lines, and hard-to-reach areas edge trimming
When your yard needs clean, well-defined lawn edges, heavy-duty mowing, winter snow removal, and seasonal debris clearing, Yarbo's modular system is designed to support every season. One Core with interchangeable modules helps simplify year-round yard care while reducing the need for separate seasonal equipment.
Products Features
Support & Care
What does a trimmer actually do that a lawn mower doesn't?
Unlike a handheld trimmer that requires you to walk every edge by yourself, the Yarbo Trimmer uses RTK-GPS navigation — no boundary wires, no physical markers. Map your trimming zones once in the Yarbo App, and it follows those defined edges autonomously from there. Zones can be adjusted anytime as your yard layout or priorities change.
How does the Yarbo Trimmer navigate edges and borders?
Can this trimmer handle complex yard layouts?
Yes. As a robot, the Yarbo Trimmer works across varied outdoor environments — fence lines, garden borders, driveway edges, uneven Canadian turf, and sloped edges that a handheld trimmer takes far longer to cover manually, maintaining consistent contact along property boundaries where handheld tools often struggle to keep an even line. Map multiple trimming zones in the app and manage each area independently, so it works through your property systematically rather than requiring you to move section by section.
How is this trimmer different from doing it manually?
Manual trimming typically adds 30 minutes to an hour onto every mow — a task that gets skipped when time is short and shows immediately in how the lawn looks. The Yarbo Trimmer, as an autonomous robot, runs on a set schedule and maintains consistent edge definition throughout Canada's shorter growing season with minimal manual trimming.
Does the Yarbo Trimmer work alongside a robotic lawn mower?
Yes, and it's designed to. The Trimmer module attaches to the same Core unit as the Lawn Mower module — one robot handles both open-area mowing and precision edge trimming by swapping modules as needed. No separate machines, no manual follow-up after each mow.
Is a robot trimmer worth it if I already manage my lawn manually?
Edge trimming is one of the most time-consuming finishing tasks in lawn care, and one of the easiest to let fall behind. Pairing the Trimmer module with your Yarbo Core keeps borders consistently defined on a schedule you set, without adding to your weekend workload — extending what your existing robot can do rather than introducing a separate tool.
  • Weather conditions
  • Carrier issues
  • High seasonal demand
  • Email: support@yarbo.com
  • Phone: +1 (631) 818-1850
  • Yarbo App support system
Fast DELIVERY
Flexible Payment Options
30-Day Trial
