Understanding Different Types of Mower Blades
Standard Blades: Often called 2-in-1 blades, these are the most common type found on push mowers. They’re designed for simple cutting and side discharge, making them reliable for everyday mowing.
Mulching Blades: Mulching blades feature a curved design that chops grass clippings into fine pieces, allowing them to fall back into the soil as natural fertilizer. They’re perfect if you want to boost lawn health without bagging. For eco-conscious mowing, these are highly recommended.
High-Lift Blades: These blades create strong upward airflow, making them ideal for bagging clippings. If you deal with tall grass or want a cleaner-looking yard, high-lift blades are your best choice. These blades are often preferred when handling tall, thick, or wet grass.
Low-Lift Blades: Designed for sandy or dusty environments, low-lift blades reduce dust clouds and extend mower life. They’re quieter and ideal for yards where airflow isn’t as crucial, such as those with sandy soils.
Gator Blades: These blades combine mulching and lifting action, giving you versatility. They’re popular among lawn enthusiasts who want mulching benefits with the added bagging efficiency.
Anatomy of a Lawn Mower Blade
Material Composition: Most mower blades are made from high-carbon or alloy steel for strength and durability. Hardened edges ensure they can withstand regular sharpening. This rugged composition is essential for equipment designed to tackle rough terrain, roots, and rocks.
Length and Width Specifications: Blades come in a variety of sizes. Always match the exact length and hole configuration recommended for your mower to avoid imbalance.
The Role of Sharpness in Grass Cutting: A sharp blade cuts grass cleanly, while a dull one tears it, leaving jagged edges that dry out quickly. That’s why sharpening and timely replacement are crucial.
Signs It’s Time to Replace Blades on Lawn Mower
Uneven Grass Cutting: If your lawn looks patchy even after mowing, dull or damaged blades are likely to blame. Grass tips turning brown after mowing? That’s a sign the blades are tearing rather than slicing.
Excessive Vibration: A bent or unbalanced blade can cause vibrations. In autonomous mowers using RTK-GPS for centimeter-level precision, this vibration is particularly dangerous as it can negatively impact navigation and potentially damage sensitive components. Any vibration means it’s critical to rebalance or replace the blade immediately.
Physical Blade Damage: Check for chips, bends, or cracks. Any structural damage means it’s time for a new blade.
How to Replace Lawn Mower Blade (Step-by-Step Guide)
Disconnect the spark plug to prevent accidental starts.
Wear gloves to protect against sharp edges.
Socket wrench or blade removal tool
Wooden block to hold the blade in place
Replacement blade
Tilt the mower on its side with the carburetor facing up.
Use a wrench to loosen the bolt holding the blade.
Remove the blade carefully while noting its orientation.
Position the new blade in the same orientation as the old one.
Tighten the bolt securely but avoid over-tightening.
Reconnect the spark plug and test the mower.
Sharpening vs. Replacing: Which Is Better?
How Often Should You Replace Blades on Lawn Mower?
Clean blades after each mow.
Avoid mowing over debris like rocks or branches.
Store your mower in a dry place to prevent rust.
Rotate between sharpening and replacement for balanced performance.
Compatibility and Choosing the Right Blade for Autonomous Mowers
OEM vs. Aftermarket Blades
Thick, lush lawns → High-lift blades
Sandy soils → Low-lift blades
Eco-conscious mowing → Mulching blades
Matching Blade Type to Grass Conditions
Yarbo Lawn Mower Blades: Standard vs. Pro – Built for Heavy-Duty Performance
Standard Yarbo Blades (Cutting Disc System): These use multiple small, lightweight steel blades mounted on a cutting disc. They’re designed for frequent, light-to-moderate mowing and fine mulching.
Replacement is cost-effective, with Yarbo offering a 40-piece blade and bolt pack that makes maintenance simple. This setup is ideal for homeowners who want consistent cuts without high upkeep costs.
Yarbo Lawn Mower Pro Blades (Straight Blade System): The Pro module is built for heavy-duty performance. It uses larger straight blades — and even dual-deck options — that provide stronger lift, wider coverage, and aggressive cutting power. The Pro module is engineered to handle tall, thick, wet, or overgrown grass, or even dense warm-season grasses common in the southern US. It features dual 300W cutting motors and offers adjustable cutting height from 0.8 inches to 4 inches. This system is perfect for larger properties, dense grass, or tougher mowing conditions and also high-end property management users such as Golf Courses and Professional Turf Farms.
Yarbo Lawn Mower Pro Blades (Straight Blade System): The Pro module is built for heavy-duty performance. It uses larger straight blades — and even dual-deck options — that provide stronger lift, and aggressive cutting power. With a cutting width of up to 20 inches and dual 300W motors, the Pro’s blades are perfect for larger properties, dense grass, or tougher mowing conditions.
Check the model number in your mower’s manual and match it with OEM specifications.
Yes, with a bench grinder or sharpening tool. Just ensure the blade remains balanced afterward.
Inspect after every 8–10 mowing sessions. It is recommended to replace the blade every three months The replacement cycle of the blade is related to usage and lawn density, and should be replaced more frequently if necessary.
They can be, but OEM guarantees a perfect fit and durability.
Recycle them at a metal facility, but ensure sharp edges are covered.
Absolutely. Sharper blades reduce resistance, making mowing faster and healthier for the grass.
