What Is a Robotic Lawn Mower?
The Technology Behind How Do Robot Lawn Mowers Work
Mapping Lawn: They use GPS wireless mapping technology to navigate your lawn.
- Navigation: Sensors + GPS + cameras map your lawn, avoid obstacles, and plan mowing paths.
Operation: Frequent, automatic trimming keeps your lawn tidy and healthy.
Smart Control: Manage everything via an app — set schedules, check progress, and customize mowing zones.
Battery Power: Eco-friendly, rechargeable batteries eliminate gas and oil messes.
So, how do robot lawn mowers operate in practice? After the initial setup and mapping, your robotic mower automatically leaves its docking station according to your scheduled settings. It systematically navigates your lawn using GPS and onboard sensors, adjusting its path to avoid obstacles, pets, or children while trimming your grass with sharp, energy-efficient blades.
Handle slopes and uneven terrain
Navigate complex layouts
Maintain large lawns using GPS-guided paths
Technological Advancements in Robotic Mowers
GPS & RTK: Precise, wire-free navigation.
AI & Cameras: Advanced obstacle and boundary detection.
Smart Home Integration: Control with Alexa, Google Assistant, or the Yarbo app.
Lawn Mower Setup: How to Set Up a Robotic Mower
Choose the Docking Location
Place the wireless docking station in an open, level area with strong satellite signal access.
Power Up the Docking Station
Ensure it’s connected to a power source and functioning properly before proceeding.
Install the RTK Antenna:
Place the Yarbo RTK base station near your yard.
Connect via the Yarbo App
Open the Yarbo mobile app to begin the guided setup process—no technical skills required.
Map Your Lawn Using RTK Technology
Use the app to initiate RTK-based boundary mapping—no perimeter wires needed.
Define the Working Area:
You need go around with your robot lawn mowers using the app and define the areas your want it to mow, know are the working zones, you can set up up multiple zones as well as the no go zones.
Calibrate and Customize Settings
Adjust the cutting height, mowing schedule, and zones as well as the mowing patterns directly from the app.
Finalize Setup and Test Run
Complete calibration and run a quick test to ensure everything is functioning as expected.
Enjoy Smart, Hands-Free Mowing
With setup complete, Yarbo will take over your lawn care with intelligent navigation and automation.
Key Components of a Robotic Lawn Mowers
Power Source
Cutting Mechanism
This allows for a cleaner cut and promotes healthier grass growth through mulching—where tiny grass clippings fall back into the soil as natural fertilizer.
Navigation and Boundary Definition
Boundary Wire Navigation: Many models require a physical boundary wire installed around the lawn's perimeter. This wire creates an invisible fence, guiding the mower and preventing it from straying into driveways, flower beds, or neighboring yards.
GPS and RTK Technology: Advanced robotic mowers now use GPS-based mapping, with some incorporating RTK (Real-Time Kinematic) positioning for centimeter-level accuracy—eliminating the need for boundary wires.
Sensors and Safety Features
Collision Sensors: Detect obstacles and change direction to avoid hitting them.
Lift and Tilt Sensors: Stop the blades immediately if the mower is lifted or tilted to prevent injury.
Rain Sensors: Some models automatically return to their charging dock when it starts raining to avoid damaging wet grass.
Benefits of Using Robotic Lawn Mowers
Cost and ROI Analysis
| Category | Price Range | Ideal For |
| Entry-Level | $800 - $1,500 | Small lawns (under ¼ acre) |
| Mid-Range | $1,500 - $2,500 | Medium lawns (¼ - ½ acre) |
| Premium | $2,500 - $4,000 | Large & complex yards (½ acre+) |
Tip: If your lawn care expenses exceed $50/month, a robotic mower can pay for itself in 3–5 years.
If you are having trouble deciding on which lawn mower would suit you based on your lawn size. Read our guide to make an informed decision.
Thinking about upgrading to a robotic mower? Explore your options and find the best model for your yard today!
Common FAQs About Robotic Lawn Mowers
Do robotic lawn mowers work on uneven terrain?
Yes! Most models handle slopes up to 30-45 degrees, though high-end versions with all-wheel drive tracks can tackle steeper inclines.
Can robotic mowers handle large lawns?
Yes, depending on the model. Some can mower such as Yarbo can mow up to 6 acres using GPS-guided navigation and multiple charging cycles.
Are robotic lawnmowers safe for pets and children?
Absolutely! They come with safety sensors that stop the blades when lifted or when an obstacle is detected.
Do Robot Lawn Mowers work in the rain?
Most robotic mowers have rain sensors and will return to their charging dock if it starts raining. However, some models can operate in light rain.
How much maintenance do robotic mowers require?
Minimal maintenance is needed—just occasional blade replacement, wheel cleaning, and software updates.
