Best Lawn Mower Sizes Guide 2025 | How Much Does a Lawn Mower Weigh?
Discover how much a lawn mower weighs in 2025 with our complete guide. Compare weights by type and find the perfect mower for your lawn care needs.
Selecting the appropriate lawn mower is crucial for maintaining a well-manicured lawn. One of the key factors to consider during this selection process is how much does a lawn mower weigh?
This question matters more than many homeowners realize. The weight of your mower impacts ease of use, cutting quality, and your lawn’s long-term health.
In this 2025 guide, we explore how much a lawn mower weighs across different types, including the weight of riding lawn mowers and how heavy a push mower typically is, so you can choose the perfect mower for your yard.
Lets begin.
Why Lawn Mower Weight Matters
Let's address the elephant in the room first, in case you are wondering why does it matter how much your lawn mower weighs?
The Risk of Soil Compaction
Understanding how much does a lawn mower weigh helps you avoid soil compaction. When a heavy mower frequently runs over the same patches of grass, it compresses the soil, making it difficult for water, oxygen, and nutrients to penetrate.
Studies show that compacted soil can reduce grass root growth by up to 50%, leading to weaker, patchy lawns.
Issues with compact soil - Infographic by Juan Rodriguez
Expert Opinion:The University of Minnesota’s Turfgrass Science team states that soil compaction is one of the primary reasons for declining turf quality, particularly in areas with high foot or mower traffic.
Maneuverability Due To Weight
Lighter mowers are easier to maneuver, causing less strain on the handler as well as the lawn. Light weight reduces the risk of scalping the lawn on uneven terrain. Heavy mowers, especially when used on wet soil, can leave tire marks or ruts, leading to an uneven lawn surface.
Types of Lawn Mowers and Their Typical Weights
Lawn mowers come in various designs, each tailored to specific lawn sizes and user preferences. Below is an overview of the common types of lawn mowers and their average weight ranges:
Manual Reel Mowers
How much does a lawn mower weigh if it’s manual?
Manual reel mowers are the simplest form of lawn mowers, relying solely on human power. They are eco-friendly and ideal for small lawns.
Manual Reel Mowers
  • Weight Range: 22 to 150 pounds
  • Considerations: Lightweight models are easier to push but may require more passes to achieve a clean cut. Heavier models, while more challenging to maneuver, often provide a more consistent cut due to increased momentum.
Electric Push Mowers
If you’re asking, “how heavy is a push mower when it’s electric?”
Electric push mowers are powered by electricity, either through a corded connection or a rechargeable battery. They are known for being quieter and requiring less maintenance than gas-powered mowers.
  • Weight Range: 15 to 80 pounds
  • Considerations: Corded models tend to be lighter but are limited by the cord length, making them suitable for only smaller yards. Battery-powered models offer more mobility but may weigh more due to the battery's weight.
Gas-Powered Push Mowers
Gas-powered push mowers are favored for their power and ability to handle thicker grass, more challenging terrains, and larger lawns.
  • Weight Range: 44 to 150 pounds
  • Considerations: These mowers are generally heavier due to the engine and fuel tank. While they offer more power, the added weight can make them more challenging to maneuver, especially in tight spaces.
Robotic Mowers
Robotic mowers are autonomous devices that mow the lawn without human intervention, guided by boundary wires, sensors or GPS systems. These smart innovative devices are well adjusted to different types of terrains and offer many smart features to improve your lawn health.
Robotic Mowers
  • Weight Range: 13 to 400 pounds
  • Considerations: Smaller models are suitable for residential lawns and are lighter, while commercial models designed for larger areas are heavier due to bigger batteries and more robust components.
Remote Control Mowers
Remote control mowers allow users to control the mower from a distance, offering precision and safety, especially on challenging terrains.
  • Weight Range: 130 to 1,900 pounds
  • Considerations: The weight varies significantly based on the mower's size and intended use. Heavier models are typically designed for commercial use and can handle rough terrains and large areas.
Riding Mowers
Riding mowers are suitable for large lawns, allowing the user to sit and control the mower, making the task less physically demanding.
Riding Mowers
  • Weight Range: 300 to 1,200 pounds
  • Considerations: The weight depends on the mower's size, engine power, and additional features like grass collectors or mulching kits. Heavier models often provide more stability and cutting width.
Zero-Turn Mowers
Zero-turn mowers offer a high degree of maneuverability with the ability to turn on the spot, making them ideal for lawns with many obstacles.
Zero Turn Mower
  • Weight Range: 600 to 1,900 pounds
  • Considerations: These mowers are typically heavier due to robust engines and larger frames, providing speed and efficiency for large properties.
Factors Influencing Lawn Mower Weight
Several factors contribute to the overall weight of a lawn mower:
Deck Material
The material of the mower deck significantly affects its weight.
  • Steel Decks: Durable but heavier, offering longevity and resistance to impacts.
  • Aluminum Decks: Lighter than steel and resistant to rust but may be less durable under heavy use.
  • Plastic Decks: The lightest option, suitable for electric mowers, but may lack the durability of metal decks.
Deck Size
A larger deck covers more ground per pass but adds to the mower's weight. Wider decks are common in riding and zero-turn mowers, contributing to their substantial weight.
Engine or Motor
The power source impacts both performance and weight.
  • Gas Engines: Heavier due to the engine's mass and the fuel required.
  • Electric Motors: Generally lighter, especially in corded models; however, battery-powered versions include the battery's weight.
Additional Features
Features such as self-propulsion systems, grass collection bags, and mulching capabilities can add to the mower's weight. While these features enhance functionality, they may also affect maneuverability.
Other Benefits of Light Weight Lawn Mowers:
Lighter lawn mowers offer numerous advantages, from ease of use to better fuel efficiency.
Ease of Maneuverability
One of the key factors influencing lawn mower selection is maneuverability. A lightweight mower is significantly easier to navigate, making it perfect for lawns with multiple sections or tight spaces. Since less pressure is required to operate it, mowing becomes a smoother and quicker task. Lighter mowers also handle slopes with ease, reducing strain on the user while ensuring an even cut.
Pro Tip: If your lawn has intricate landscaping or obstacles like flower beds and trees, a lightweight mower allows for better control and precision.
Reduced Fatigue On Handler
Mowing can be exhausting, especially if your yard is large or requires frequent upkeep. A lighter mower reduces physical strain, making the process more comfortable and efficient.
Expert Insight:According to lawn care specialists, using a lighter mower can reduce physical exertion by 30-50%, making it a great choice for homeowners with larger lawns or those who mow frequently.
Increased Portability
A major benefit of lighter mowers is their ease of transport. Whether you need to move the mower between different parts of your yard, transport it to a second property, or help a neighbor with their lawn, a lightweight mower makes the process hassle-free.
If storage space is limited, a lightweight, foldable mower is an excellent option. Many modern electric mowers weigh under 40 lbs, making them easy to lift and store.
Power Efficiency
Lighter mowers, particularly battery-powered and electric models, consume significantly less energy than heavier gas-powered alternatives. They require less power to operate and cut grass efficiently without excessive fuel consumption.
Electric mowers use 30-60% less energy compared to heavier gas-powered models, reducing both electricity costs and carbon emissions contribute to lower carbon footprints, promoting a more sustainable lawn care routine.
Easier Maintenance
Lighter mowers generally have fewer mechanical components, which translates to less maintenance and fewer repairs. With simpler designs and fewer moving parts, they require minimal servicing, making them a practical and cost-effective choice for homeowners.
Regular maintenance for lightweight mowers includes blade sharpening, battery care (for electric models), and occasional cleaning to extend their lifespan.
Healthier Soil and Grass
Unlike heavier models that may compact soil over time, lighter lawn mowers minimize ground pressure. This prevents soil compaction, allowing better airflow, water absorption, and nutrient penetration to the grassroots and about 25% better root growth according to a study by University of Minnesota.
Lawn Care Tip: If soil compaction is a concern, aerating the lawn annually and using a lightweight mower can improve grass health significantly.
Adaptability to Various Terrains
Lighter mowers are well-suited for diverse terrains, including hilly, uneven, and compact spaces. They provide better control and stability on steep slopes, where heavier models might tip over or be challenging to push.
Convenient Storage
If storage space is limited, a lightweight mower is an excellent option. These mowers take up less room and can often be folded or stored vertically, making them ideal for small garages, sheds, or apartments.
Selecting the Right Mower Based on Weight
When choosing a lawn mower, consider the following:
  • Small Lawns: A lightweight manual or electric push mower is ideal.
  • Large Lawns: A riding mower may be necessary despite its heavier weight.
  • Uneven Terrain: Lightweight push mowers handle slopes better.
  • User Strength: Ensure you can safely operate the mower’s weight.
1. Does mower weight impact lawn health?
Yes, heavier mowers may compact soil, while lighter ones are less likely to damage delicate grass.
2. How much does a standard lawn mower weigh?
A standard push mower typically weighs between 40-100 lbs, while riding mowers range from 300-1,200 lbs.
3. Are robotic lawn mowers heavy?
Robotic mowers weigh between 13-400 lbs, depending on the model and battery size.
4. What is the heaviest type of lawn mower?
Zero-turn and remote-controlled mowers can weigh up to 1,900 lbs due to their powerful engines and larger frames.
5. How much does a commercial lawn mower weigh?
Commercial mowers can weigh anywhere from 600-1,900 lbs, depending on size and features.
