News
Understanding Yarbo NetRTK: What It Is, When to Use It, and How It Works
Yarbo NetRTK is now available on all Yarbo models, free for the lifetime of your Yarbo. No antenna, no base station, no installation — just connect and go. Here's everything you need to know.
What Is Yarbo NetRTK?
Yarbo NetRTK (Network RTK) is a network-based high-precision positioning service that gives your Yarbo centimeter-level accuracy. Unlike a traditional local RTK base station you have to mount, power, and align in your yard, NetRTK delivers correction data over the internet — so there's no base station to install and nothing to set up. Just connect over the internet (Wifi-Halow/Wifi/4G), and your Yarbo is ready to work with precise, reliable positioning across your whole yard.
How it works, step by step:
  • Your Yarbo connects to the internet via Wifi-Halow, Wifi, 4G
  • It requests correction data from the Yarbo NetRTK cloud service
  • The cloud identifies nearby reference stations and generates a correction packet for your location
  • Yarbo applies the correction in real time — centimeter-level accuracy, no antenna required
NetRTK vs. Yarbo Data Center: Key Differences
Yarbo Data Center (DC) Yarbo NetRTK
Hardware required Yes — outdoor antenna, wiring, elevated mounting No local RTK hardware required
Installation Medium to high difficulty (ladder, drill, cabling) App-based setup, a few minutes
Coverage range Local range around the Data Center Network coverage area — no single-point limit
Upfront cost DC purchase required No additional hardware cost
Moving homes Full reinstallation required Simply reconnect and remap
Network dependency Not required — fully local Requires internet connection via Wifi-Halow/Wifi/4G
Offline operation Supported Not supported — requires active internet connection for positioning
Neither option is universally better — they're designed for different situations. Read on to understand which is right for you.
Why Use Yarbo NetRTK?
  • 🚀 Forget the Antennas, Enjoy Hassle-Free Setup.
    Skip the extra antenna, roof mounting, and signal alignment. With Yarbo NetRTK, high-precision positioning is delivered through the network, so setup becomes simpler, faster, and easier.
  • 🌐 One Network, Your Whole Yard.
    Yarbo NetRTK delivers high-precision positioning through network-based correction data — no local base station, and no dependence on your home Wi-Fi range. In supported areas, Yarbo keeps working accurately across your whole property, free from the router-range and base-station placement limits that hold back traditional setups.
  • 🚚 Move Home? Just Bring Yarbo.
     Moving, or caring for a second property? No base station to uninstall and re-align. Bring your Yarbo, connect to the network, and you're precise again in minutes.
Already Have a Data Center? NetRTK May Still Help
If your DC is working well, there's no urgency to switch. But a few scenarios make NetRTK worth considering:
  • Signal gaps. Trees, buildings, or terrain can block DC line-of-sight. NetRTK can fill those gaps without additional hardware.
  • A second property. Your DC only covers its installed location. If you're considering a fresh install at a new home, NetRTK is the simpler solution at any additional address.
  • Backup positioning. You can keep both services configured and switch between them under Yarbo App → Settings → Positioning Service.
⚠️ Note: DC and NetRTK cannot be active simultaneously. Switching between them requires a manual map recalibration in the app.
NetRTK Lifetime Free: What's Included
As of August 1st, 2026, Yarbo NetRTK is free for the lifetime of your Yarbo — all models, no exceptions.
Included:
  • Full NetRTK precision positioning service — no subscription, no annual fee
  • App-based setup and management
  • Ability to switch between NetRTK and DC at any time
⚠️ Note: Please use the in-app coverage checker to confirm availability at your address before setup.
Requirements and Compatibility
Network connection
Your Yarbo needs a stable internet connection to use NetRTK. Supported types:
  • Wi-Fi HaLow — if you have a Yarbo Data Center, your Yarbo can use the DC's HaLow link to reach the internet and run NetRTK
  • Wi-Fi — connect to your home network as an alternative to 4G
  • 4G — on models equipped with the 4G Connect Kit, with no extra hardware to buy
Regional availability — NetRTK availability varies by region. To check:
  • Open the Yarbo app
  • On the login screen, tap Check NetRTK Coverage
  • Zoom to your yard and tap Check Coverage for This Area
If your area isn't covered, subscribe to notifications and we'll alert you when service reaches your location.
Q: Is Yarbo NetRTK really free forever? Any hidden costs?
Yes. The NetRTK precision positioning service is included free for the lifetime of your Yarbo — no subscription, no annual fee, no hidden charges.
Q: Which Yarbo models support NetRTK?
All Yarbo models. You can check coverage availability and activate the service directly in the app.
Q: Do I need to buy extra hardware?
No extra hardware is required for NetRTK itself. On models equipped with the 4G Connect Kit, 4G is built in; you can also use home Wi-Fi, or the DC's Wi-Fi HaLow connection, if you have or plan to buy a DC.
Q: What if my area isn't covered by NetRTK?
A DC base station is the current alternative for uncovered areas. You can also subscribe to coverage notifications in the app — we'll alert you when service reaches your location.
Q: Can DC and NetRTK be used at the same time? How do I switch?
DC and NetRTK cannot be active simultaneously. Switch between them at any time under Yarbo APP Settings → Positioning Service.
⚠️ Note: Switching positioning services causes a map offset. Manual recalibration is required after switching.
Q: I've moved to a new address. Does NetRTK still work?
Yes. Bring your Yarbo to the new location, connect to the network, and NetRTK resumes automatically.
⚠️ Note: A new address is a new yard, so you will need to set up your map and re-initialize NetRTK Service in the app after moving.
Regular price $7,499.00 CAD
Sale price $7,499.00 CAD Regular price $8,299.00 CAD
Sale price $10,199.00 CAD Regular price $11,299.00 CAD
Regular price $11,499.00 CAD
Sale price $11,499.00 CAD Regular price $12,799.00 CAD
